The stern rails in Hunter are parallel but uneven. The upper lies 3" more aft than the lower. Furthermore, there is no straigh T section to attach the engine mount. I've seeing in the archives where people spent +$1000 in welding to place a motor mount. Today, I found an inexpensive alternative. Using the motor mount from Westmarine I attached an 10" section of 3/4" pvc to the T section. At the bottom end I used an elbow, followed by a 3" section, followed by a end stop/plug. Just picture an L under the engine mount with the end of the PVC facing forward and hitting the lower rail. This prevents the motor mount from piviting forward. To prevent the engine from flying aft and away I used a bungee cord oround the engine shaft. Cost $11 plus mount, less than 1 hr labor. Worked great today. If you have a heavier motor you may consider using 1" pvc or placing alluminum inside the pvc. For a 3 hp engine, I had no problems.Hopes this helps with all you new Hunter owners.abecomments appreciated, sorry don't have digital camera for pictures
