Outboard Question. Help!
981
Catalina Capri 14.2 1670 Rochester, MN
No. In my experience most big boats are controllable at low speeds in reverse.
Ward H
Nov 7, 2011
3,842
Thanks to this thread, I had some ideas to try when trying out my motor on my Newport 17 couple days ago. First time out so I wanted start with just motoring, didn't even take the mast and sails.
When backing up out of the dock, using the motor and rudder together seem to work best. For forward motoring, I left the motor straight and used the rudder for steering. That worked very well. It also let me sit on the opposite side of the boat to balance out the motor weight, since I did not need to reach the OB tiller.
Jun 12, 2010
936
Oday 22 Orleans Marina, NOLA
I went with a fixed motor - I get by but in reverse there is little control and at slow forward I could use more control. It's very doable but I'd rather have the ability to pivot the motor - you get a lot more fine control at low speed and in tight spots.
