outboard motor
Oct 30, 2019
6
I'm Looking for input on installing an outboard motor on AV27 to get a boat into water with aux power to get in and out of slip. Its a long story this is what I have to deal with. thank you in advanceMike
w1wlv
Sep 23, 2015
7
My VEGA(#971) runs by TOHASTU 6HP with inboard removed.Works fine and happy with it.Since it is a long shaft, it seems working good in a little swell(10ft).Thanks, Simon Elvee Lee
hl1lv@...
Apr 28, 2000
691
We used a 15 hp Yamaha to push Williwa from Petersburg, Alaska to Port Townsend, WA with no problems. No problems AFTER we reinforced the transom with half inch plywood on the inside and half inch aluminum bars on the outside. The PO had just bolted the engine mount to the transom with a plywood backing plate on the inside. For some reason he got away with it. When we tried to use it that way, the transom oil canned alarmingly with stress cracks showing all around the motor mount. Our solution, recommended by one of the local fisherman was to "Get Joe". Joe fabricated two aluminum bars to go on the outside, through bolted to the plywood backing plate on the inside of the transom It may not be the best solution but it worked splendidly. If you stop this video Williwa Down the Inside Passage, Part 1 Williwa Down the Inside Passage, Part 1 Retirement adventure. Three guys crew the sailing vessel Williwa, a 27' Albin Vega, on a 6 week adventure down the Inside Passage. Starting from Southea... View on youtu.be Preview by Yahoo at 4:53 you can see a close still shot of what I am describing.
