Outboard motor size
C
Charles Bowers
Sully, At one time I had to have my 9.9 repaired so I slapped a 4 horse on my 23 for a couple of weeks. That was enough to get me into and out of my slip but there was no reserve power. I now have a 26 O'day that I push around with an 8 horse Yamaha Hi Thrust and can get about 5.5 knots at 3/4 throttle. My recommendation would be to consider an 8 Hi Thrust as the minimum for your 23. Happy sailing, Charles
Jan 22, 2007
268
Oday 23 Cedar Creek Marina Bayville NJ
I have a 9.9
that came with our 23. It's an old Johnson sailmaster. Runs like a charm plenty of power. I would not think of going any bigger. However there were days backing out of our slip in high wind and rough water that we were glad to have all the extra power. It takes alot to swing the boat through the wind and waves to head out before you drift into a neighboring boat. For that reason alone I would replace it with another 9.9 if my OB was to die. I am on a lake and don't need to worry but don't forget about water currents. Fair winds to you sir. Scott
May 31, 2004
858
Catalina 28 Branford
My two cents
I have a two stroke 8 hp on my Oday 23, and it provides as much useful thrust as the 9.9 two stroke it replaced. The 8 hp pushes the boat at hull speed at 3/4 throttle. I have had an experienced sailor aboard who thought a 6 hp two stroke would also be adequate, but I think that would mean no reserve power for rough conditions or emergencies. IMHO, I would say an 8 hp two stroke is as small as I would go. If you go with a four stroke, I think a 6 hp would be ok (remember, a four stroke generates significantly more torque and therefore more thrust than a two). In fact, I wouldn't be surprised if you had to go with a four stroke, as the major manufacturers seem to have phased out small two stroke engines.
Scott
6hp 2-stroke
I have a 6hp Merc (2-stroke) on my O'Day 23 and have been happy with it. It's what came with the boat. In my (limited) experience, the power is fine, but I wish it had an extra-long shaft instead of just the long shaft.
A
Adam
Vote of 4-stroke 8hp
I have a 8h 4-stroke on my boat, been very happy with it: quieter, uses less fuel, no oil/fuel pre-mix... More importantly, it has the power when you need it: facing wind, waves and currents.
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
An 8 hp would work fine
I have a 1999 two stroke Johnson Sailmaster 8 that I simply love and it pushes my O'Day 222 right along. The shifting lever is located right in front of the engine which makes life easier, and it has an alternator for charging my house battery. The engine is light enough for me to carry in and out of the cellar. The four strokes are even better but they're heavier and you may need to install a transom bracket that will take the weight and engine thrust. I think that an 8 hp outboard on that boat will get you through the Tiverton Basin stemming a Spring tide current. A 6 hp engine might be a little small for that boat in your area.
