P
Patrick
I have a 1974 seafarer 29. The boat has an outboard motor that sits in a compartment in the back of the boat. The motor drops through a trap door in the bottom of the hull when you want to use it. For this reason, only a short shaft motor will work. The motor will shift into reverse and you can see it churn up the water but the boat will not go backwards at all. I took the prop to a shop that said it was already a "sailboat" prop. I'm wondering if there is more than one kind of sailboat prop and if a different one would help. It is a 15hp motor. Is a more powerful motor the answer? I should add this boat is new to me and the old owner states it didn't go in reverse for him as well.any suggestions would be helpful.thanks..
