Outboard motor parts.
Jun 26, 2024
4
O'Day 28 Black Rock Harbor, CT
I'm looking for a Magneto coil assembly for an Evinrude 1987 30 HP Evinrude.
What online parts supplier is most likely to have it? Thanks
Nov 6, 2006
10,152
I have refurbished a couple of old (mid 80’s) OMC outboards. I was able to get the parts from a local Johnson dealer .. the Bombardier folks who took over have maintained a pretty decent supply of parts..
Likes: jimd333sail
Sep 24, 2018
3,994
Catalina 30 MKIII Chicago
Marine Engine has gone above and beyond to do some research for me when there were multiple part numbers. However, I usually just use amazon and ebay
Likes: jimd333sail
Sep 24, 2018
3,994
Are you looking for new or used? I know this part is a bit pricey. Honestly, You'd be better served with a solar panel if it's just the charging part coil that went out
Mar 2, 2019
629
Oday 25 Milwaukee
A magneto coil is going to be needed for ignition . I'm pretty sure it wont run without it .
Oct 31, 2022
72
Catalina Capri 22 Huntington
I enjoy getting old Evinrudes/Johnson outboards running and have restored a couple of them. Marineengine.com has been one of my go to online stores for parts. I always copy a paste the part number into Ebay or Google Search just to see if I can find the part somewhere else for less money. Marine Engine has great exploded diagrams with the part numbers. Ebay often has lower prices, some of these parts are, of coarse used. But sometimes you get lucky a find someone selling what you need as NOS.
Sep 24, 2018
3,994
This 30HP is most likely going to have electronic ignition. There's some simple resistance tests that can be done to check the coil. CDI Electronics has specs published along with the factory service manual. I have both if needed
Jun 26, 2024
4
Thank you for your input. This is turning out to be a winter's project. Thanks who all the advice I've got on this forum, I'm confident that I I'll get her started.
