I have a 1985 O'Day 26 which uses a 9.9 Yamama outboard. This engine weighs about 107 pounds and the lift, I believe these are also referred to as auxil- iary outboard brackets, that is now on the boat does not have enough spring power for one to easily lift it up out of the water. Has anyone had any experience with this problem? West Marine has two models, a Garelick with a 9.5 inch verticle lift and also one with a 15.5 inch vert- icle lift both stated to lift 170 to 175 pounds which should be sufficient for my engine. Has anyone had any experience with these products and do you think they could be mounted on my boat/motor? Appreciate any response. Thank you.
