Issues
Four stroke engines not only weigh more than their hp-equivalent two stroke cousins, they also generate more torque. This means that a four stroke engine is going to be putting more strain on the mounting bracket than a two storke engine of equivalent hp. That is why many mounting brackets are not capable of handling a four stroke engine.It is easy to find mounting brackets that are rated for four stroke engines, but the chances are that it will not have the same bolt pattern or footprint as your existing mounting bracket. You will probably have to drill new holes in your transom to accomodate the mounting bolt pattern of the new bracket. You may also want to beef up the transom by epoxying a piece of marine-grade plywood to the inside of the transom where the bracket will be mounted. This will help spread the load. However, the biggest pain in this process will be if you need to replace your spacer block. This is that triangular hunk of fiberglass that is mounted on your transom in between the bracket and the transom. Its function is to allow the engine sufficient space to have the engine tiller arm extended fully, as well as keeping the engine at the proper angle to the hull. Your new four stroke rated bracket might be able to do these jobs without the spacer block, but if you still need that extra space, you will have to replace it. All of the four stroke brackets I have seen have a much wider footprint than the two stroke brackets. The Oday spacer blocks were specifically made to be just wide enough to accomodate the two stroke brackets. If your four stroke bracket is too wide, then you will have to fabricate a new spacer. I have seen various suggestions on this site about how to do that. The one that appealed to me the most was to use Star Board or similar material. No maintenance, no painting, no fuss.Good luck.
