Outboard Fuel Line Questions
azguy
Aug 23, 2012
337
Catalina 22 Lake Pleasant
I got a question about fuel lines for outboards. I never seen one with a fuel filter cut in, how come..?? I just picked up this fuel filter and was planning on splicing it in but thought I would ask first....any reason not to :confused:
Also, is the location of the primer ball critical to it working correctly..? I usually see the primer ball close to the fuel cell and then a few feet of hose running to the motor. Can I re-rig my whole fuel line so the fuel filter is close to the tank and move the primer ball closer to the motor so I do not have to lift the fuel storage lid to reach the primer ball :confused:
Thanks
914
Boston Whaler Montauk New Orleans
Thanks
Azguy, before I got my fuel/water separator filter, I had one of those in-line filters. It was about halfway between the bulb and the motor. My bulb was about 2/3 of the way from the tank to the motor. Always worked fine.
azguy
Aug 23, 2012
337
This is great news. My boat came with two fuel line set-ups. Both had the primer bulb about 12" from the tank and then about 3' of hose to the motor.
I think I'll re-do one with the fuel filter about 12" from the tank and the primer bulb about 12" from the motor.
After sailing for a few hours the fuel line has to be re-pressurized to get the outboard to start with a pull or two. It's a pain to lift up the fuel tank door, that I'm usually sitting on..... yada, yada, yada..
Thanks...just curious how many people run a fuel filter in their outboard fuel line....I mean why not, right..?
914
For several years, I had just the in-line filter. The last time I had work on the motor, about a year ago, the mechanic suggested a fuel/water separator, which I agreed to. After numerous trips, on one trip my motor killed, and ran very rough getting back to the launch. I checked the separator at home, and it was full of water. I tightened up my fuel line connections, emptied the current tank of gas, and haven't had a problem since.
Sailm8
Feb 21, 2008
1,750
Hunter 29.5 Punta Gorda
Thanks...just curious how many people run a fuel filter in their outboard fuel line....I mean shy not, right..?
I had this problem and was fixed by replacing the connector between the hose and the engine. The rubber gasket in the connector was sucking air.
Beneteau 323 Annapolis MD
I dunno. I think if the filter can be seen through, I'd put it AFTER the bulb so you can see if the fuel is coming through the bulb and filter.
JerryA
Oct 17, 2004
549
Tanzer 29 Jeanneau Design Sandusky Bay, Lake Erie
Not that glass filter
I would agree with others that a filter is a good idea. Just not that filter pictured. I've used that glass, screw together filter style on cars, and have had friends that have used these. The result was the filter loosening up and leaking gas. I even heard one that had the glass break. Those applications did use the filter in a pressurized enviroment though between pump and carb. If it were me I'd use a one-piece filter design instead.
JerryA
azguy
Aug 23, 2012
337
Glass does scare me a bit, however, if it's in the gas tank compartment it won't really get disturbed....especially if the primer ball is outside that compartment. I'll never open it unless I'm refilling it, which isn't often.
The PO said he filled the 6 gallon tank twice a year...From the slip it's all of 5 minutes to sails up and motor off...
Feb 20, 2011
8,048
if you are talking about out board fuel tanks all i have ever seen had a screen on the end of the pickup tube only.......
regards
woody
Well, plus one or two under the cowling. ;)
May 4, 2005
4,062
I've always see those filters after the bulb.
-but they are screw apart to allow replacing filter. They have caused air leaks and bad running. (o rings usually.)
the water /fuel separators are much better. racor makes a small one for OB's ..
also, every OB Ive seen has a small micron filter on the block.
Sep 26, 2008
566
- - Noank CT.
If the filter pictured is really glass and not a plastic I agree not to use it only because it is glass and could break suggest a all "plastic" filter like in attached picture. I have used one like it for years and have not had a problem.
pic credit from Moeller web site same manufacture as the one you show. This one is a one time use unlike the one you show where you can replace the filter element cost about $5 and will last for years. I change mine every two years just cuz it is cheap insurance. Most auto parts stores carry them or a similar one.
Dec 29, 2008
805
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
There will be a filter inside the engine cover already, but I like the idea of adding one in the fuel line. That one inside the engine cover is a ***** to get at. Because of this thread, I'm going to add one between the tank and the primer bulb (which I have always seen right up near the engine where you can pump it prior to starting the engine).
Sumner
Jan 31, 2009
5,254
We put one of....
...these on the boat and so far has worked great after about 3 months on the water and motoring a lot....
http://www.tohatsuoutboardparts.com/Fuel-Tanks-and-Lines.html
The bulb is between the filter and ....
... the motor and never had problems priming and holding prime day after day. I've read that if you do have problems priming hold the bulb vertical (I think that was it) but we usually primed once and then never again on the trip.
Ruth made...
... a cover for it to protect it from the sun. A great filter with a water separator. More info on the install here.....
http://purplesagetradingpost.com/sumner/macgregor2/outside-36.html
Sum
[FONT=Arial, sans-serif]============================
Our Endeavour 37
Our MacGregor 26-S Pages
Our Trips to Utah, Idaho, Canada, Florida
Mac-Venture Links
[/FONT]
May 24, 2004
7,164
CC 30 South Florida
Some try to protect the bulbs from the sun and the elements but they are cheap enough to replace, go for the convenience. It does not matter where it is placed along the fuel line. Some engines have a built in filter comparative to what you intend to install.
