I have a 1990 MacGregor with an old 9.9 Johnson outboard. I'm afraid the moter has seen its best days and in need of replacement. I have a transom mount on the stern,( port side) that has about a 9 inch drop or notch if you will where my motor mounts onto the stern. My issue is with my outboard that when I move the throttle handle to port I hit the side of the motor well restricting my ability to move the bow to starboard without lifting the throttle handle and physically turning the motor to the side with the throttle handle vertical. I thought about the mount that bolts on the outside of the stern and lifts and drops the motor into the water, however, I was concerned that the throttle handle would not be long enough from my seat to steer the boat? Any suggestions on the motor mount?
Thanks!
Thanks!
