yes, run the engine
...I use the ear muff type flusher over the water intake. Of course, the prop cannot be engaged. You must run it long enough to get the motor up to temp and open the thermostat to get the fresh water into the head area. Running it in a bucket will work but the water will heat up quickly so keep the fresh water hose flowing to replentish.There should be a flush plug, just to the right of the gear oil plug... I have one on my Tohatsu 9.9, but the motor must be off to use it so the fresh water still won't get up to the motor head.
