tom h
My friend didn't spray oil into his outboard last year and now the piston is froze. I was trying tho think of a way to get it to move and one idea is to take out the spark plug and spray in ether (starting fluid). The replace the spark plug and connect wires to the housing and end terminal of the plug. Standing some distance away, and behind some protection, connect the wires to a battery making a spark. The explosion should move the piston, if it was frozen in the going down position, I think. Another way is to spray nut cracker into the pison area dn alet it do its thing, then try to move the piston using the starter. I like the idea of the explosion. Blow the whole thing up if it doesn't work. Any ideas other than these two for freeing a stuck piston? Is anything wortht he effort or is the motor junk? My guess is if the rust is too much, then the rings will be fused to the piston and the walls. yo might free tit from the walls, but not the pistons. He might have to replace the piston head, riongs, and resleave the unit, if it can be resleaved,
