won't fit
this is a much discussed topic, check the archives for other thoughts. Bottom line is that none of the newer style 4 cycle OBs will fit, event the Johnson. Catalina recommended 6 to 8 HP in their old brochure, but almost everyone I know uses a 9.9 or higher. There are many options, your final choice is Power vs. fit.... One consideration is to modify the opening, I saw a project on a website and I'm sorry but I don't have the link. Try google maybe. But the owner had a 10 HP Yamaha. He lowered the bottom about an inch and added additional backing support for the motor bracket by glassing in a piece of plywood. BTW this additional backing is often suggested by the factory if adding a larger OB than the 6. Anyway, he also enlarged the upper part enough to accommodate the cowling. Of course, the cowling interferes with the transom hatch when the motor is in the up position, so he modified that also.When I replaced my old 15 HP Johsnson sailmaster (very low profile) with a Tohatsu 9.9 I found that I could tilt the motor up if I REMOVED the cowling, then covered the exposed head with a good quality canvas cover. So I leave the motor down all the time, when I'm using the boat. I leave the motor in neutral when sailing. The only time I ever pull it up when sailing is when I participate in the occasional beer can race, which isn't very often. Plus it's convenient being able to start the motor whenever I feel like it, just like an inboard. This has worked for me so far, but some day I'll modify the opening....but it's low priority, now. The most important thing is to get a motor with electric start, remote control and 12 volt charging system. It is totally worth the extra money. Many remote models don't come with tiller arms, but that's okay because it's useless with the C27 hole anyway. If the 8hp comes with remote package (I know honda has one) and it will fit when tilting up, then that's probably all you'll need to get in and out of the harbor. If you plan to do a lot of motoring, get the larger motor and figure out away to make it fit, or take my option.Last consideration is weight. I am a big, big Tohatsu fan. The following 20 inch shaft 9.8 Tohatsu has everthing you need, plus it only weighs 81 LBS!!!http://www.outboardsales.com/Outboard_Motor_Pages/Tohatsu_Outboard_Motor_Pages/tohatsu-9-8-hp-4-stroke.htm
