Attention Outboard Manufacturers!
This is one area where a savy outboard manufacturer could really set themselves ahead of the pack. Most small outboards produce 6-8 amps at cruising speed (some of the Hondas are rated at 12 amps I believe), which is enough to keep the starting battery charged but nowhere near enough to keep a decent house bank well charged. As noted earlier, the regulation is also usually quite poor. So...why not build an 8-10 hp 4 stroke outboard with a 30-40 amp 3 stage regulated alternator? Properly designed, it would be like having a small generator onboard, in that you could run the motor in neutral and use just the charging capability while in dock or anchored. Yes, it would make the motor a little heavier, and a bit more expensive ($300-$500?) but it would sure be a big seller amongst the small sailboat crowd. One potential downside would be when trying to move the boat while charging a heavily depleted battery. I'm not quite sure how much hp it takes to run a 40 amp alternator to full output, but perhaps they could include a switch that would cut the alternator output if full power to the prop was needed. So, to any of you R&D guys from Honda,Mercury, et al... I'd be happy to help you test a prototype!!
