Outboard Bracket Wedge
Steve Braverman
I thought I would post a photo of my latest upgrade. This was discussed on this forum last month and some people expressed interest. This is what I did. I made the wedge out of solid mahogany, and lowered the bracket about five inches on the transome. The motor is now vertical and the prop is in the water all the time, even in rolling seas with a person on the bow.
Jul 25, 2005
29
Oday 25 Monroe Lake Indiana
Sure looks GREAT!
Steve - Why did you choose to go down 5"? What type of adhesive did you use? How did you choose the angle? - I assume you used the old wedge - How did you get the old wedge off? Does going down 5 inches impact the integrity of the transom? - I am not an engineer - but boy - seems like there is a lot stress on that transom - and now it has moved down - What did you use as reinforcing on the locker side? May have more questions - I attached a plate to my old wedge - it is working - but I have a bad feeling about it - just looks like a lot of stress on the transom - I am also not sold on the bolts - I have the same bracket - garelick 090 - and those bolts just don't seem strong enough - boy am I paranoid! I thought I had the bracket low enough = but again I am not satisfied! - I am kicking myself in the rear for not waiting on an extra long shaft - but I was told those are soooo difficult to get! by the way - looks GREAT! - quite impressed!
Steve Braverman
Good Questions
When I bolted the new bracket into the holes used by the old bracket, the prop was only half in the water. I simply used the original lower holes as my new upper holes, and drilled new lower holes. I figured the less holes in the boat the better. I decided not to use any adhesive between the wedge and the hull. The bolts are doing all the work anyway, and this way I can easily remove it if necessary. I may bed it with 3M 5200 over the winter. The get the proper angle I held a bubble level against the transom and measured the distance from the level to the transom. I know it's crude, but this isn't rocket science anyway. The motor is pretty much vertical now. Getting the old wedge off was no problem because my boat had no wedge, just a square piece of plywood under the old bracket. The old bracket had an adjustment for trim. I can't see how moving the bracket down could negatively effect the transom. If anything, the transom is stronger closer to the edge. My boat has plywood laminated into the original fiberglass on the starboard side to reinforce it. You are smart to be paranoid about the bolts. The bolts that Garelick supplies are junk! Throw them away and get some grade 8 stainless carraige bolts. For reinforcement inside the boat I used some aluminum angle-iron that I found. Two pieces about 12" long, and I don't see any flex. The extra long shaft is hard to find, but it's the only way to go. I bought the Yamaha High Thrust 9.9 and am very satisfied with it. I originally wanted a Honda until I saw the price. Then I was going to buy a Tohatsu, but they were back-ordered until August. The Yamaha costs about $500 more than the Tohatsu, but it's well worth it. Just having the shifter on the tiller instead of the side of the motor makes maneuvering the boat so much easier.
