outboard alternative
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
While browsing craigslist today I saw a 28 lb thrust trolling motor & battery for real cheap... Anybody know if that would be enough to push 8'6" inflatable dinghy with 2 adults in it? Not looking to break any speed records but would it be a little faster than rowing?
Thanks!
Manny
Ross
Jun 15, 2004
14,693
I read once somewhere that sustaining 10 pounds of thrust with paddles is about the liimit for a kayaker. But paddles are more efficient than propellers.
caguy
Sep 22, 2006
4,004
I have the Minn Kota 28 and it work just fine. You won't be able to go great distances but it will get you to shore. I ran mine up and down the channel at MDR with about a 12-15 knt head wind and it still made some pretty good speed, and that was with just a battery jumper battery. I video taped it but can't find the file now. The nice thing about it is that it stores so easily and it is easy to load. The 8.5 I have for it now is a bit of an overkill but a lot of fun. What was weird about it was that the tiller throttle was backward so I would speed up when wanting to slow down and vice versa.
Jun 7, 2004
383
Schock 35 Seattle
I have a Torqeedo electric motor on my 10' Zodiac. It pushes the boat at about 3 knots cruise and 4.6 knots top speed for very short periods. It develops about 68 lbs of thrust which is 2.1 times what the trolling motor develops. I don't know if the math works but I would estimate you would go at about 1.5 knots.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
the one caveat I'd have is that you'll have fairly limited range with that and no way to easily recharge it; so keep the oars handy...
Oct 2, 2006
1,517
Jboat J24 commack
Just be sure its a saltwater unit as the freshwater units will fail pretty fast
Nov 1, 2009
1
Oday Oday 30 LaHave, Nova Scotia
You will not be able to use it in high wind conditions, it will go faster then rowing in light winds and small waves.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Short Range
Unless you load the dink up with a couple of large deep cycle batteries, your range will be limited. And the batteries are heavy. If you only need it for short distances, and have a good way to recharge should work fine. Small outboards on ebay are pretty cheap also.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
It will work very well in mild conditions but do not attempt to fight wind or current. Years ago I had an old motorcycle battery which refused to die with all the abuse of being deep cycled and a 20 lb thrust motor and it worked very well to get to and from shore (200 yds) in a protected basin. The battery finally died after left unused for over a year.
Oct 22, 2008
3,502
Of course, the advantage of a small outboard is that they're very easy to "recharge"... with a jerry can of fuel along. A Tohatsu 3.5 HP engine is light, about 40 lbs. with fuel, add a 2 gallon jerry can, and you can run for almost NINE hours. The batteries to give you a couple of hours of run time on a trolling motor are probably heavier than that.
Manny
Oct 5, 2006
983
Thanks guys, it sounds like this could work. I've made an inquiry to determine if it is for saltwater rated, I didn't realize that there are freshwater and saltwater trolling motors. Anybody know how much run time could be possible with a group 27 deep cycle battery?
I saw a 4hp outboard that listed today for $75 but it had sold by the time I called:cry:
Thanks,
Manny
MrBee
Dec 30, 2008
425
Irwin 34 Citation Middle River, Md.
For a dingy I would look for a small Outboard. something in the range of 2 - 4 hp. Also that size motor will have the fuel tank integral to the motor so nothing extra to move around, just a motor. The motor alone would weigh less than a battery for the electric motor. Yes it would be a bit noisier but... Everything is a compromise. for a couple hundred or less you can get a small outboard. I never had one but the "Cruise and Carry" seems popular and they are regularly on ebay.
Brian
544
Bristol 43.3 Perth Amboy
Amp draw
I have an electric trolling motor that I have used on my Flying Scot. It moved us just fine. The outboard literature should tell you how many amps it draws at different settings.
From that you can figure out roughly how long you can run in minutes based on the amp hours of the battery. Of course, the amp hours are calculated with a specific load. Calder's book has a table I think on this topic.
Oct 14, 2005
2,191
Manny...
almost all the guys in my marina that tried electric trolling motors on their dinks have given them up for a low hp gas engine. Wind and waves work against them as the charge runs down--batteries are heavy and go straight to the bottom if the dink gets tipped!
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
This has not been my experience. I've been using a Minn Kota 40-lb for over 5 years in the salt and the only harm is a bit of corrosion on the aluminum housing which made the paint fleck off. A wire brush, some sandpaper and black spray-paint and good as new!
A 28lb is a bit "light" - I find the 40-lb adequate for getting to the shore from anchor or putting around the bay. I can charge the battery either off the engine's alternator, the AC charger, or a solar panel - no need to carry gas! And the battery and motor are WAY easier to store than a gas outboard and fuel.
One of my biggest peeves is in a quiet anchorage, when the loudest noise even the big powerboats make is the anchor-chain, then you hear WWWAAAAAAAAAAAAA from the outboard on the dinghy (and this is often at midnight when the crew is returning from the bar...). Give me electric ANY day.
druid
"Coatue" Crown 28
Manny
Oct 5, 2006
983
I prefer quiet
druid
"Coatue" Crown 28
I'm with you Druid, I don't like the sound of a little outboard all revved up. I don't think my dogs would like it either, that's one of the main reasons I was thinking of a trolling motor. Storage space is getting to be sparse on my 27', I can toss a trolling motor in my lazarrete and not have to worry about fuel spilling out of the tank and into the bilge. I think I can find a spot to store the battery also, having a fuel can to trip over on deck is not fun.
Manny
Quoddy
Apr 1, 2009
241
Hunter 260 Maine
Quiet and clean
We have had a good experience using electric for our tender. There is a lot to be said for quiet, no fume, start every time, no maintenance, light weight, no carbon propulsion.
We have been using a 30lb fresh water electric with 30ah AGM on a 8 foot Zodiac with one person aboard for 4 years. Our mooring is 430 yards from the dock in a fairly open mooring field so wind and current can be issues. With a starting voltage of 12.5v you can go about a mile at 2.4mph. We recharge at home with solar panels to make it zero emission.
Things to consider: A rapid draw on such a small battery, even if it is a AGM,which can tolerate it, will pull it down quickly with a correspondingly rapid rebound.
With 30lbs I have not lost headway, but 15k of head wind would certainly be a challenge.
Fresh water model is stainless and plastic so with care I’m hoping it won’t be a problem. I froze the tension screw by not paying attention.
Speed is a huge factor in range so low speeds are best. If the motor is not a modern digitally controlled model then speed is controlled by resistance so going slower does no good. Ours is the old style.
As you can see even with a less than perfect system it can work great for the type of use I am putting it to. For greater versatility, which I am heading to, I would say a higher thrust digitally controlled, still a fresh water model for the price, with a larger battery( or two battery system ,one in backup) may be the way to go. The latest addition to the system is a Battery Bug which is supposed to continuously monitor battery condition.
Elec dinghy motors
The one missing link in these discussions is how you use your dinghies. Since distance is part of the equation, in addition to speed and endurance, please tell us how you use yours.
For instance, where we use our dinghy can be mixed on any given weekend. One: short hops to shore at an anchorage or mooring field, maybe 200 yards two or three times a day for the two or three days of a weekend. However, we sometimes like to go out for breakfast, which is at least a five minute dinghy ride at "top speed" on a 10.2 Zodiac with a 9.9 HP engine. I doubt an electric motor would work for our intended usage.
When we had our old 8'-4" dinghy with a 1.2 HP motor, we simply couldn't make that breakfast trip.
So help us understand how you use the motors since one size doesn't fit all.
The quiet of elec motors is nice, but I don't mind dinghy noises after I awake, and when down below can't recall ever being awakened or kept awake by a dinghy engine. We don't sleep in the cockpit (it's too cold here - or too hot in the Delta).
Manny
Oct 5, 2006
983
Intended use...
Well... I don't plan on doing any poker runs on the dinghy:D
Primarily it will be for hopefully short trips to shore (a few hundred yards) to run to a restaurant or bar, and to shuttle the dogs for bio breaks. I don't find rowing to much fun so the dinghy is not being used as much as it could be.
Manny
