On the hard
I'd add a few more things to the checklist:1. Grease the through-hulls. Check all the hoses & clamps that go to them too. Much easier to replace while on dry land.2. Check the cutlass bearing on your prop shaft.3. Check the rudder bearing and the wheel steering mechanism.4. Repack the prop shaft seal if it hadn't been done in years.5. Service the engine (lubrication, coolant, belts, filters, zincs, hoses, etc.) Don't forget the waterlift muffler.6. Service each of the anti-siphon valves (exhaust, head, etc.).7. Blow out the air vents/hoses for the fuel, water, and holding tanks.8. Clean all in-line water filters. Replace any water hoses & fittings that show signs of mold growth. 9. Winterize all plumbing if storing until next season.10. Clean the bilge area. Inspect keel bolts for corrosion. Clean the bilge pump intake line & filter-screening. Check the bilge pump float switch & wiring -- replace if necessary.11. Check all the standing and running rigging for corrosion, wear, damage.12. Ditto for stanchions and lifelines.13. Test all running/steaming lights.BTW: When you launch again, have the prop shaft alignment checked *after* the standing rigging is adjusted & the boat has been taken out on a test-drive.
