out haul cleat
Oct 27, 2023
84
hunter 290 toronto
Hello, have a new to me H290 and just setting up the running rigging for the first time after haul out. The outhaul line has a locking stopper cleat on the boom by the mast where the line comes out but the line just hangs when cleated. Any suggestions where I should wrap the tail end of this line or just let it hang? approx 5 ft hangs.
thanks
Colin
Several options are availabe to the sailor.
If this is what "locking stopper cleat" means:
I found it worthless on my rig. I have a low stretch high tech line of for the outhaul. It would not stay cleated. I tired coiling the line and tucking it in over the taut outhaul. The line just fell to the deck after a tack or two,
I opted to use a small regular cleat. With a cleat hitch the line is secure and easy to adjust. I can coil the tail and tuck it in between the outhaul line and the boom. Line stays put till needed.
A third option is to get one of those line bags. You can affix them to the mast or boom and tuck the tail in the bag.
  • Helpful
Likes: JamesG161
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
On my H23 I just coiled the line with fairly small loops and let it hang, on one of the reefing rams head hooks.
Oct 6, 2007
1,184
Hunter H30 1982 Chicago IL
Mine was at that location and I didn’t like it. I added a turning block at the mast base, ran the line through that and a deck organizer back to a cabin top rope clutch in the cockpit. Now I can adjust the out haul without leaving the cockpit. That said, when it was on the boom, I just coiled and hung the line on an adjacent reef line cleat.
Jun 2, 2004
3,676
I riveted on a cheek block and a cam cleat to the boom for both the outhaul and the topping lift
used the extra jam cleat for a second reef point
