Osmotic Blisters
C
Chuck
I have been following the interesting discussion regarding hull blisters. What experience and advice can anyone offer regarding new Catalina hulls e.g. 2001 - 2002? Should these have a barrier coat applied prior to applying bottom paint? Specifically the boat will be in fresh water initially and moved south in the not too distant future.
L
LaDonna Bubak - CatalinaOwners
Don't see why not
I can't think of why you *wouldn't* want to apply a barrier coat before the boat is launched, especially if it's going in fresh water. LaDonna
C
Chuck
LaDonna, Thank you for your response. I was inquiring to determine if the barrier coat is truly needed in addition to several coats of bottom paint. The barrier coat application is quite expensive to have done. I recognize that there was a period were blisters were fairly common on many boats. However, with the new resins, and now warranties, I was wondering what Catalina owners had / were experiencing with new Catalinas. Are owners of new boats having this (barrier coat) done, or does bottom paint provide enough protection? Regards,
Dick
Two Different Purposes
Chuck, As long as they build fiberglas boats with gel coating there will always be a need for a barrier coat. Newer boats with newer materials, and equally important, newer construction process controls, greatly extends the time before you could possiby experiance blisters. The bottom paint you are talking about helps in reducing the buildup of algae and/or facilitates the removal when time to clean the bottom. It really does nothing in blocking water migrating over time into the gelcoat and eventually the fiberglas. The barrier coat is the best insurance you can buy in reducing water transfer to the hull. Believe me, when you go to eventually sell your boat, nothing will turn off a prospective buyer quicker than blisters. Barrier coat the boat, it's well worth it, even with todays newer boats.
Tom
Hmmm....Adding barrier coat might not make as much
a difference as you would think. Contrary to popular belief (check
C
Chuck
Thanks
Just a brief note of thanks to those who responded with advice.
Dick
Good Info
Thanks for the tip on the great web site. Really interesting reading. dic
