Original Main Sail finally ripped
28
Catalina 30 Kent, NY
So, I've have the boat out twice so far this year. First time the water pump went belly up and I had to order a new replacement rubber paddle. That was an easy fix.
Yesterday, I tore the original main sail.
http://imgur.com/p8sb95K
I'm two for two this year on major problems.
Just looking for advice on where to buy a new sail for this thing.
Thoughts on repair, perhaps ? If its even for a back up.
I've always "known" that I've had a tall rig, but in measuring the sail, my measurements come out to be somewhere in the middle of what the standard rig and tall rig sails state on website, so I dunno. Any other way to confirm 100% on whether I actually have tall rig? Hull number doesn't seem to give any hints.
1984 Catalina 30 - Hull #3687
Apr 19, 2011
456
Hunter 31 Seattle
I went through this site and got a Doyle sail that I couldn't be happier with.
You can check bacon sails for rig dimensions or buy good used sails...
Good luck!
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
That's "repairable" if only for a backup sail...
I did one last year with a similar rip, overlapped the rip by a consistant 1/2" and run two rows of wide Zig Zag stiching to hold it together... Then repair/reinforce the leach by a foot or two with a thin strip folded overand double stiched as well...
You should be able to do it with a standard sewing machine as your only going thru 2 to 4 layers....A heavier old all iron machine would be better yet and come in hndy for other sailing related projects...
Not the ultimate solution, and a new/used sail is called for, but I was happy to have a backup (just last week) when a sudden squall shredded the top 1/4 of my new to me/used/e-bay sail and I still had several miles to get back to home port...
Now I have two patched and repaired main sails...but only a $100 invested....(and I'm still sailing....) maybe next year I'll bust out for a real all new sail from Bacon Sails
http://baconsails.com/sailsearch
May 25, 2011
28
Thank you all for those links. I don't have a sewing machine, but I have taken it to a sail maker/repair shop. Initial quote for repair is a little over $100. Which I can't complain about. This will at least provide me some time to get a new sail and then I'll also have a back up.
