h23 keel types
There were some swing keel h23s , there were even a very few wing keel with a retractable center board/ keel , I saw this combination at the h23 nationals , the boat did well, it also had other upgrades, it was from somewhere near toledo and the skipper wa a guy named Ken I think, if I were going to trailer sail I might give serious thought to the swing keel design , also check out the area where u intend to sail, you could not sail a swing keel where I sail because of water depth , a swing keel might go in more shallow water than a wing keel , but that does not mean it will sail in more shallow water/ big difference, I would also check out these archives about problems relating to swing keel, , broken lines , broken bolts, trunk crack etc etc, the h23 wing keel is a great boat we have owned ours for 8 years and although I had never given any thought to racing, I did for the first time this season and will definitely continue. think about where and how you intend to use the boat before u make the final choice, good luck , Mike B
