I was trying to remove the thermostat cover on my 2QM15 Yanmar (79 H33), and even with the correct size wrench... the heads stripped.
I guess in hindsight I should have gone for one of those ez-out things, but I went for the angle grinder and ground the heads off. Well, the cover came off okay (and the bolts came out thanks to a pair of handy dandy vice grips), and boy oh boy was that thermostat shot! Anyway, in the process of grinding down the heads, the surrounding areas got a little "beaten up".
I'd like to just replace it, but Torresen lists the part as no longer manufactured. I'm awaiting a "help" email to them in trying to locate a replacement.
I'm hoping someone here might know where one be found.
My alternate plan is to break out the Dremel this time and try to clean up the hole areas so a washer and/or bolt head can get a good grip to hold the cover down.
Thanks
Thanks
