Notes from the old school.
As an old school wood butcher, furnture maker and refinisher, I have to disagree with both prior posters, but also observe that they are not exactly "wrong".That said, I never use anything finer than 120 grit on teak. It has been my experience that finer grit sanding clogs up the pores and interferes with both an even application of stain (the best way to get the color you desire) and the bond of your varnish. Second, it has always been my practice to wipe teak with acetone prior to glue up as the oil interferes with the adhesive bond. As a result of assembly lessons learned, I now do the same prior to finishing and for the same reason.I often get several years out of finishes if they are not damaged and I attribute that durability to good preperation and maximizing the adhesive bond of the varnish.So, the posters clearly aren't wrong, it is just more likely that their finish work will not last as long as it might otherwise.
