		Dave Young
I have been sailing my almost new 460 for about three months now and have a couple of problems with the forward holding tank, and am looking for advice on where to look.Problem 1 is the selector which sets to Wet or Dry bowl.  The selector does not settle in the Dry position, and when you pump, there is a lot of back pressure.  I often have to hold the selector to the Dry position to get it to work right.  think the thing is broken and needs to be replaced.  But if It can be fixed, all the better.Problem 2 is the apparent capacity of the same forward holding tank.  I think it is either 20 or 25 gallons, but it appears to fill up very fast.  When we pump out the tank, the discharge looks way too clear and clean, as if there might be a leak in the system letting fresh water in while under sail.  Is there something that you'd recommend I can check here?  Maybe this is related to problem #1?Unfortunately I live about 200 miles from the boat, so I have to plan ahead to bring the right tools and plan time to do appropriate maintenance.Your comments are appreciated!
