Bob
Ok, She's out of the water. I was told I have either a bent shaft or worn cutlass bearing so I am replacing both as well as installing a dripless shaft seal. I am also going to put a couple fresh coats of trinadad bottom paint on, replace the tru hull stopcocks, buff and wax the hull and replace the boot stripe. I only have 3 weekends with her out any thing else I should do in this time? 88' H30
