Have a Hunter 38 and was wondering what other owners are doing for on deck fuel storage. Going to use plastic jerry cans - tips on securing would be appreciated.
By treated is that pressure treated lumber?I carry 5 jerry cans of diesel while cruising. I have a treated, then painted, 1x3 attached with SS U Bolts, one each end, between stanchions. I then used 1-1/2 inch nylon strapping with plastic buckles. I routed 1-1/2 inch slots so I could use 2 straps per jerry can. One goes around horizontally, one vertically and they snap together. They are solid as a rock in 6 foot waves. When I need fuel, I get one to the cockpit and then use a clear plastic jiggle siphon you can buy on Amazon for less than $9. Takes 1 min 40 seconds to transfer 5 gallons.
Just curious as to the PVC tube tied to the life lines.......fender board?? chart storage??Wrong photo - tried to load 2 one in previous post is the jiggle siphon, this mismatched one to see the stand-off
What about fishing gear? ?Just curious as to the PVC tube tied to the life lines.......fender board?? chart storage??
