Tough Question
Hi Matt:The question your asking will be hard to answer, mainly because the life of any engine, gas or diesel depends entirely on the maintenance and upkeep that was preformed by the previous and or current owner. I've seen high hour engines, both gas and diesel that were in excellant shape, but opposed to that, I've seen fairly low hour engines that were good for nothing but anchors. In both instances, maintenance or the lack of, was the reason for the condition of the engine. I'm afraid that there is no magic bullet here. There are arguments for both gas and diesel. Gas engines are cheaper than diesel, in cost and repair, but can be tickier as boat engines sometimes set up for long periods of time between use and unless proper care is taken, are prone to carburation problems. Moisture also causes problems in the ignition systems, so it get's back to proper maintenance. In addition, some folks like me just don't want gas on a boat. Diesels are more expensive, but are tougher and normally longer lasting, even when neglected, and as they operate without an ignition, are a less complex engine. There is also a less likelyhood of fire/explosion with diesel, BUT, are more expensive to repair in the event it's needed. I have a 21 year old boat with a diesel engine that runs like brand new, however, it has always had very good maintenance. Unfortunately, this is not the case in a lot of instances.Based on your obvious concerns about the engine, I would suggest that whatever decision you make, unless you go with a new motor, extra precautions be taken as to having the engine checked by a qualified mechanic.Tough decision Pal, Good Luck!!
