Old LPG Cylinders
Debra Blatnik
Does anyone know if new overfill protection devices can be added to old LPG cylinders? Also, is there any way to tell a vertical cylinder from a horizontal? I understand that they have internal differences. (Am I mistaken?)
Dec 2, 1999
15,184
Looks like they can be retrofitted!
Debra: I just read that they can be retrofitted. Looks like the cost is about $30 for valve and re-certification. I assume that you have aluminum tanks! Doubt that you would mess with this on a steel tank anyway. You just need to determine how many years left on the tanks before they need to be replaced. Then you can decide if it is worth it. As far as Horizontal/Vertical tanks, I have no idea how to tell, BUT I believe that there is a difference.
Dec 2, 1999
15,184
more info for you!
Debra: Here is some more information for you. Maybe you can find some additional information from this site. http://www.airstreamdreams.com/category.html?UCIDs=69543
Tim Schaaf
vertical and horizontal tanks
The LPG in your tank is exactly what it says....a liquid. When your valve is opened, some of it can expand, and forms a gas. The gas is lighter than the liquid, hence it rises. Hopefully, the exit to the tank is at the top, so the gas can go out. Vertical tanks and horizontal tanks are each designed to have the gas go out of what should be the highest point. Where you get into trouble is where you tip a vertical tank onto its side, and make it a horizontal tank. In that case, what will come out is not gas, but liquid, which is not what you want! I am not positive of the consequences.....and am not curious! Anyway, where the hose attaches is the top.
