Old Horizon Depth Sounder
Dec 27, 2011
279
Oday 272 Pensacola
O'Day 272 1987 vintage. I've owned it 5 yrs.
Documentation from PO shows a Horizon DS45 manual with '98 date. Looks very similar, but not identical. Has started allowing water to get into back side cover in cabin.
Appears to have disintegrating O ring that holds instrument to face ring. Parts for DS45 does not show this.
Where can I get info/part to replace this O ring?
Thanks.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
If I couldn't locate one, I'd try gasket cement or even butyl Tape. It shouldn't take much to seal the case.
Be sure to get all the moisture out of it before sealing it back up. such as keeping it with a fan in a warm dry environment or plenty of desiccant.
Ken
Joe
Jun 1, 2004
8,313
You may have the DS 1 series... the UK precursor to the American made DS 45 and 50.... parts for those older units no longer exist.... Luckily the DS 1 depth and speed systems are virtually unbreakable... unlike the wind system. You could take the instrument to a supply house like Grainger and try matching it up... if they don't have anything.. take Ken's advice. Shouldn't be too hard a fix.
279
Oday 272 Pensacola
Photo of DS45 appears to show face plate & instrument as one piece. Mine is 2 pieces, with O ring to fit on instrument, then push into faceplate with groove for O ring. May have to plaster it together with sealant like suggested...
Jun 19, 2004
365
Island Packet IP 32 99 Forked River, NJ
You might try DMI - I think they're in CT - Google them. It's a long shot but ...
Dec 27, 2011
279
Oday 272 Pensacola
DMI says they don't carry parts for Horizon equipment. Guess I get to try the 'cram it full of sealant' option.
Dec 27, 2011
279
Oday 272 Pensacola
Plastered it back together today. It is a DS45. Not sure why mine has 2 pieces when display of DS 45 shows it as all one piece.
