How much solar panel wattage you need will probably depend on how much you use the boat continuously. If you use it on weekends, with an occasional overnight, and use lights, and maybe run a laptop for a few hours, then you can probably get by with a 15 watt panel with a charge controller. That's 1 amp per hour max in sunlight. That's what I have and it works well. Between that and the lame alternator on the motor, the batteries seem to stay up well.
If you're going to be out for multiple nights at a time, then Sum's setup makes more sense.
