Dale I
I'm curious how it has affected your style of usage and sailing behavior. Has it caused you to sail less because you now need an extra crew member (that is not always available) to handle the dock duties and you can no longer single hand like you use to? Or has it opened up new places farther away to venture to that you could not access with your day sailer? Has it presented a faster drain on your budget with the replacement/upgrading/maintaining of LARGER sails, equipment, slip fees etc. than you'd anticipated.... Any surprises that you didn't anticipate with 'moving up'... Any thoughts that your previous boat was *really* the *right* size...? Does anyone go back to sailing smaller rather than the 'terminal trawler' in the twilight years of physical mobility....? How large a boat can you reasonably single hand if conditions are good? Have you got a line 'holster' in your slip to catch the bow on returning to eliminate the need for a dock hand? Whats your set-up for single handing....? I need help setting up my 34 for just that...
