DO NOT BREAK THE PISTON RINGS !!!!!
If the engine is apparently 'frozen', using the sxtarter to 'break it loose' will most probably break the piston rings.
Open/remove the injectors, and squirt in a tablespoonful of MMO and let it soak for several DAYS.
Take a long handled 'breaker bar' and socket and attach it to the crankshaft pulley attachment oolt and GENTLY attempt to 'rock-it' back and forth. If the crankshaft begins to rotate without much force, slowly turn the crankshaft for several revolutions but dont FORCE it!!!!!
If you get resistance to the breaker bar with socket keep adding MMO to the combustion chamber (and wait a day or two for it to soak, then repeat with the breaker bar + adding MMO as above until the cranshaft freely turns. Dont FORCE the crankshaft, dont use a screwdriver in the teeth of the the flywheel ... and for God's sake DONT USE THE STARTER. Your goal is add MMO and trial rotations with the breaker bar until you can fully rotate the crankshaft --- WITHOUT any FORCE. NO FORCING IT unless you want to install new piston rings.
Once the engine fully and freely turns, then consider to use the starter.
Add/fill the crankcase with sufficient MMO to bring the level up to the 'dipstick' level, start the engine; but, let it IDLE only until 'warm'. Once warm slowly bring the rpm up to operating rpm (with NO LOAD on the engine -- totally in 'neutral'. This step with MMO filled crankcase will begin to 're-polish' the cylinder walls and piston ring grooves. IMPORTANT - run the engine with NO LOAD on it (especially with MMO in the crankcase).
Then after the engine has run-in for some time; then, drain the MMO (difficult to do if the engine is at an 'angle' and not straight horizontal). Then fill with straight 30 weight oil and run the engine with load but dont 'beat it'. Slowly bring the engine up to speed with load applied ... dont 'gun it'. During this section you will need to quickly/suddenly 'back down' the rpm to help re-seat the piston rings, etc.
Then change out the oil once more and replace with your choice of 'normal' oil (and 1qt. of MMO) thereafter.
Dont BREAK THE PISTON RINGS BY FORCING the engine to turn over ... be patient, keep adding MMO and wait a day or so before additional trials with the breaker bar, etc.
