I recently purchased from this fine site a replacement light fixture. The new fixture is LED and the old was CCF. When I pulled the old one out to install the LED I found three wires vs. my expectation of two wires (positive & negative). When I called Hunter they said the third wire is there for the dimmer switch and that I would have to remove the dimmer switch and replace it with a standard switch as part of moving to LED
Along the way I did a little experimentation. When I connect the positive to the blue wire (see picture) the fixture works just fine ... it turns off and on and dimmers like a champ. When I connect the positive to the blue with the red stripe wire the LED fixture is permanently ON .... the switch has no impact ... no on and off no dimming. OK so here a re my questions:
- Why?
----- Why are three wires needed is it dimming or the CCF or both that make it required and again why? 110 only need two for a dimmer...
------ Why is the blue with red stripe wire permanently hot it is clearly attached to the switch circuit breaker? and since the dimmer and light work with out it what is it really for and why is it there?
- I like the dimming function (and per the fixtures instructions it is dimmable) but by leaving the old hunter switch in place am I building up heat that that switch can't handle?
- I don't like having a hot wire run floating around through out my ceiling hooked to nothing but if I tape it off is there really any worry?
- My easiest path is wire the lights to the to the blue, tape off the blue with red stripe close it up and go sailing .... so what dangers/problems am I missing?
(FYI it is a dual switch the left side is a typical on and off switch connected to the red courtesy lights and the right side of the switch with the circuit board is the dimmer switch that controls the recessed lights I am replacing)
- Why?
