OIL WEIGHT---FOR TRANS. ON MY C-27
G
Gregg W.
NEED HELP ASAP------NEED TO KNOW THE OIL WEIGHT FOR THE TRANSMISSION ON MY C27.,CHANGING OIL TODAY-CAN YOU HELP?
Catalina 320 Dana Point
The Hurth on my 270 uses ATF, it's most
common oil used I think. What year, engine, gearbox is your boat, someone here will know with a little more info or check owner's association website for manual for your boat.
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
Oil
My C320 uses 30w auto oil in the xmsn. This info should be on the C27 site, listed above.
It's NOT the boat, it's
the transmission that is in the boat. If you have a Hurth transmission you need Dexron or Ford Automatic Transmission Fluid (ATF). Either or, but do NOT mix them. If you have another type of transmission, you'll have to do some more research. Stu
