OIL WARNING LIGHT FAULT?
17
Hunter 34 Anguilla, BWI
My oil pressure warning light started "chirpping" about a month ago after an hour or so of use, now, after coming to operating temp., the oil warning light/buzzer goes off full blast. I have about 50 - 60 hours on this oil change, and there is plenty of oil. Any way to check for a faulty sensor? Anything to look for? I live in the Caribbean and use 40w oil year round. Engine runs fin, and no smoke, etc. Thanks, Steve
Dec 2, 2003
4,245
- - Seabeck WA
Mine too, also standing by for help.
P.S. I'm so sick of it I just ordered a new sender. It'll be here tomorrow. I'll know if that was the problem tomorrow afternoon.
Del Wiese
I added guages
I added oil and water guages to my 3HM35F. Kept the warning lights, so I have both.
Jul 1, 1998
3,062
Suspect Sender
The description of chirping then going off full time sounds like the same problem I had several years ago and replacing the sender cured the problem. Remove the oil fill cap with the engine running and see if you get a face full of oil. If you do then it's the sender. On the other hand, if the rocker arms are dry then it's not. :)
Dec 2, 2003
4,245
- - Seabeck WA
Steve!!!!!
Sender arrived today. Sender installed today. Sender tested today. Sender perfect! No chirp! :)
Jim
Dirty connection
Clean the connection on the sender and retighten. Worked for me.
