When you suck the oil out thru the dip stick, do you attach what I call a spaghetti tube to shove down the tube? I use it and it seems to do better then just attaching to the dip stick tube.
Yes, I inserted a tube down the dip stick path until it stopped, then backed off a smidge so it wasn't being jammed into a blockage. As I said, my rookie mistake was not removing the fill cap, so I had quite a time getting flow, but I believe I emptied it.When you suck the oil out thru the dip stick, do you attach what I call a spaghetti tube to shove down the tube?
I did change the filter. Doesn't make sense to me to change the oil but leave a bunch of dirty oil in the filter.This is normal for marine diesel engines w/o drain plug. I did not see in your message, and assuming you did not change the oil filter.
