i recently purchased a hunter legend 40. i am trying to get rid of an oil smell coming from the bilge. The bilge had a half inch of slimy black goo under a couple of inches of dark oily water. I scrubbed the bilge and the area under the engine until it was spotless and dry. Two days later (no sailing in between) i found a couple of inches of oil smelling water in the bilge. I'm in search of the source.
At the front of the bilge is a 1.5" hole going forward through a box beam. A bit of water with greasy blobs in it sloshes out of that hole as the boat moves around at the dock. i am thinking of aiming my pressure washer into that hole and blasting it with a detergent/water mix until clean water comes out. Any reason not to do this?
thanks
-jhs
thanks
-jhs
