Oil Shelf Life
rfrye1
Jun 15, 2004
589
Hunter H376 San Diego
I change oil on my Hunter once a year. Engine gets about 50hrs a year. No matter how hard I try I usually get about 4 qts out w/Filter change. Usually buy the 5 gallon oil jug of oil because of price break. So I end up with an extra 1 qt of oil every year. I dont need to add any oil all year long.
Should a recycle last years oil, or save it. Just keep the newest extra leftover qt. Or combine them for 4 years, until I have enough for an enite oil change? I use Delo 15-40 (San Diego). I guess another concern is that the oil additives could change over 4 yrs too.
Thanks. Bob
Bob, how long do you think that oil's been sitting on the shelf at the auto parts store? :)
Keep it, use it, save $$ and some dinosaurs. :)
Additive changes won't help your old engine, 'cuz it's been running without additives since it was built.
Nov 6, 2006
10,253
Is fine to keep in the bottle, sealed.. Shake it up well before pouring together.. if the bottle sits a long time without moving, some additives may tend to settle.. no, you don't have to shake your car before starting.. that oil gets stirred/mixed very well as it lubes the engine.
Sep 25, 2008
1,096
CS 30 Toronto
mix and match
I don't know why you need to combine them for 4 years. Can't you finished last years left over, pour in 1/2 from this year and save 1/2 for next year and so on.
We've done that on cars for years.
It's not the same as buns comes in 8 and hotdogs comes in 10 conspiracy !
Nov 8, 2010
11,386
Diesel fuel and motor oil have NO shelf life..... the chemists have no idea how long before they will actually go bad.
Sep 25, 2008
7,737
Alden 50 Sarasota, Florida
Kind of off topic but the degradation of lube oil and diesel are mutually exclusive.
Diesel does degrade beginning in approx. 6 months. If you want details, a quick google search for "API studies diesel fuel degradation" will show a number of references and way too much detail off topic to the OP.
Hence the great never-ending debate about the pros/cons of filling the fuel tank prior to winter storage.
As it relates to lube oil, no such degradation has ever been found.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
you must not use Hebrew National they only come 7 to a pack :cussing:
Oct 2, 2008
3,814
Pearson/ 530 Strafford, NH
Thanks. Bob
I trying to figure your math. You buy 5 gallons and use 1 each season and have only 1 quart left. Hmmmmmmm. Maybe you're just wicked messy.
All U Get
rfrye1
Jun 15, 2004
589
Sorry All U Get
I meant 5 Quarts. Sorry, this new metric system has me all confused......... :)
Nov 8, 2010
11,386
Don. Interesting, I'll have a look. I was referring to diesel kept in good condition; away from open air and water/condensation. I had heard/read that if you keep it dry; its good.
RichH
Feb 14, 2005
4,773
.... and the reason why lube and other oils are easily 'recycled and reclaimed' and returned back to 'new' condition. That oil is already millions of years old to begin with ... just keep it sealed up and it will last approximately another few millions of years. Tribologists (lubrication scientists) will tell you that such oil never 'wears out'.
However, leave it open to the atmosphere and it will eventually oxidize and/or become the 'food' for lots of hungry microorganisms that will alter the chemical structure into such as 'asphalts and tars', etc. (but that too is convertible back to 'new' lube oil).
Sep 25, 2008
7,737
Don. Interesting, I'll have a look. I was referring to diesel kept in good condition; away from water/condensation. I had heard/read that if you keep it dry; its good.
My take-away from reading these studies is that even properly stored diesel in the complete absence of any water/moisture (a physical improbability) will degrade quickly. The properties lost and the paraffins created in degradation cannot be mitigated by the common off the shelf so-called "preservatives" making the store full/store empty a largely academic argument.
Urban myths are hard to kill.
jwing
Jun 5, 2014
503
ODay Mariner Guntersville
If engine oil lasts indefinitely, why is recommended that automobile oil get changed every 3 months, even if the car has not been driven? Have I been duped?
RichH
Feb 14, 2005
4,773
ENTROPY !!!! The fuel is cracked or distilled with heat / energy added. Entropy will dictate the slow reversal back to its basic 'resting' state.
Sep 25, 2008
7,737
Auto service industry continues to use scare tactics and lots of people waste fully spend money to oblige them. Check out edmunds.com et. al., do a search of auto industry service recommendations, etc... And you will find 7,500, 10,000 and in some cases even greater intervals. It takes most folks quite a while beyond 3 months to accumulate that mileage.
Obviously, lube oil uncontaminated by combustion by-products should last a while.
Don's right.
Just another reason to USE your boat more often. :)
I'm now refilling half a tank every three months or less. Heck, where have I been? Only the Shadow knows....:eek:
