Oil Pressure
Jun 28, 2009
33
Hunter 27 Penobscot
The boat yard launched my 1978 Hunter 27 four days ago and put it on one of their moorings. This morning we moved it to our mooring, after running for about ten minutes both the water temp and oil pressure pegged all the way to the right. I watched both for about a minute or two before shutting it down and the water temp gauge rapidly dropped to about 80 degrees, the oil temp gauge however stayed way the right. The engine is a 21 hp yanmar diesel. Suggestions on how to proceed? Thanks
Regards
BF
Jun 6, 2006
6,990
Assuming there was not an actual overheat of the engine and this is a gauge problem.
You have a wire that is common to both that is grounding out or power is getting to the sensing grounds of those sensor wires. Most likely at the helm as that is where those wires come together. pull the panel and look for chafed wires focusing on the sensor wires
The chances of a wire coming loose are much higher at the engine end. Check there first.
MitchM
Jan 20, 2005
1,031
yan 2 GMs are very sensitive to both a proper cooling (antifreeze) level and having enough oil in the engine. either fluid being low can create a situation where you get a hot temp gauge warning. (but I find it odd that on your boat that the high water temp issue occurred with a 'high oil pressure' gauge pegging at the same time. )
1) check that your over flow tank for coolant is topped to the full line, and
2) your engine oil (checked engine-cold) is between the marks.
3) check for antifreeze in your bilge. if so, coolant is escaping somewhere.
if the engine block gets really hot as it would with a 'high water temp' warning, maybe that causes a weird effect in the oil pressure sensor sending unit (though I've never heard of that happening.)
back to cooling issues: once you know both the fluids level are OK , check your wiring from the oil pressure sending unit again for chafe, etc as suggested above. after that's done i'd run the engine at low idle idle and watch the water temp gauge carefully. monitor the oil pressure gauge at the same time. if your water temp begins spiking too hot (approaching 210 degrees) you may have a cooling system issue to fix. ( I think yammers have a fail-open T Stat so I don't suspect a bad thermostat would cause overheating.) (PS- if your boat has connector hoses off the engine into a hot water tank, make sure those hoses aren't pinhole- leaking or abrading to lose coolant on the bulkhead. check for coolant in your bilge or coolant stains on your bulkhead. )
let us know what you find ?
Oct 30, 2011
542
klidescope 30t norfolk
A yanmar 2GM takes 30 min to over heat with no water in it on a cool day
Dec 28, 2014
61
Hunter 280 Mandeville, LA
I have a similar problem with the Holding & Water tank gauges on my 280. Both started to peg full a few months back. I am pretty sure it is in the wiring but not had a chance to trouble shoot it yet.
Jun 28, 2009
33
Hunter 27 Penobscot
The oil level was fine but there some coolant in the bilge. I will check the wiring this weekend.
BF
Beneteau 323 Annapolis MD
Probably once a year my fuel guage pegs to full. It was the 1/4 inch push-on connector at the tank that had worked loose. Squeezed it some and put it back on- problem solved.
Jun 28, 2009
33
Hunter 27 Penobscot
Thought it was the oil pressure sending so I replaced it but the problem persists. I'll pull the face of the gauges on Wednesday and check the connections. The water temp issue is solved. Any other suggestions regarding the oil pressure?
BF
Oct 30, 2011
542
Add a "t" and gauge weather or not tempory or perminant just to get idea where pressure is at low oil pressure could be a sign of major problems with engine thicker oil postpones those repairs
Jun 28, 2009
33
Hunter 27 Penobscot
I'm sorry but I'm a bit confused, what is a "t" ? The oil pressure is reading all the way to the right as soon as the engine starts? I ran it today for about ten minutes and it sounded and ran fine.
BF
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
a pipe tee so you can use a mechanical gauge with the electric one and double check the oil pressure
Jun 28, 2009
33
Hunter 27 Penobscot
I continue to have difficulty finding the cause of the oil pressure spike:
I checked the oil level and it is normal
I checked all the connections and they are secure without corrosion
I replaced the sending unit
As in my previous post,when I start the engine the needle on the gauge moves way to the right
Here is something I learned tonight. When the battery switch is on both prior to staring the engine the needle is way to the left (normal). When the battery switch is in the off position the needle pegs way to the right.
I appreciate your patients and comments to someone is challenged with electrical issues and color blind also (makes tracing the wires interesting)! Commnets?
Regards
BF
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Make sure it's wired as designed. I'll attach a wiring schematic. If your engine model isn't listed let me know what model you do have.
Ken
33
Hunter 27 Penobscot
Final Answer: Well after replacing the sending unit and the gauge, the problem turned out to be a wire that was not grounded, which may of you suggested.
Thank You!
BF
