hi ! got a catalina capri 26 1991 . in the control panel , there is no module to indicate the oil pressure just the engine temperature gauge. There is a printed circuit board behind the panel that used to sound when the temperature got too high but does not work anymore . I bought a module to replace it, it,s suppose to sound when temerature get too high or if the oil pressure drops. I just can't see if there is a low oil sensor installed already cause I can't find any wire hangin'out aroud the oil pan. Does anybody know somerthing about this cause when motoring , you always have to get a look at the temp. gauge in case something goes wrong.
