One more happy camper
My boat originaly had varnish on all the wood. The Chespeake sun can do a number on varnish but nothing like what you experience in Hawaii. I sanded off all the varnish and used CETOL. Life couldn't be better. When I do get a ding in the wood, just sand it and put more Cetol on it. About every other year we lighly sand the Teak and apply another coat. Can't be much simpler than that.Now when it come to sanding your handrail on top of the cabin, the easiest way is to take off the handrails off first. To do that, take a small straight edge screw driver (a little smaller than the teak plugs). Place the blade with the grain of the plug, slightly tap into the teak plugs and break them apart, now get out your power screw driver and remove the screws. W/ two handrail each side it took only me only 30 minutes to remove all the rails. As you remove each hand rail remembar to label each one as to port -stbd and which end was forward.Sand and apply all your coats of Cetol while the rails are off the boat. When reinstalling the rails, make sure you squeese a little caulk into each screw hole before puting the rail on also ensure a little caulk is in the hole of the rail and around the base of the rails.Have funMark Whitson S/V Tequila
