A friend of mine pumped out his bilge recently only to discover a fairly prominant sheen on the water. Suspecting an oil leak, he carefully went over his engine and trans, and only found a little oil - like a couple of drops - gathered at a low point. Trans and engine oil levels are fine. The bilge had been scribbed clean at the beginning of the season. What do you think is the problem?
