Oil in the bilge
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
A friend of mine pumped out his bilge recently only to discover a fairly prominant sheen on the water. Suspecting an oil leak, he carefully went over his engine and trans, and only found a little oil - like a couple of drops - gathered at a low point. Trans and engine oil levels are fine. The bilge had been scribbed clean at the beginning of the season. What do you think is the problem?
Ross
Jun 15, 2004
14,693
1 half teaspoon of diesel fuel will put a sheen on
a ten foof circle of water. Those few drops could be enough.
Jim
May 21, 2007
775
Catalina 36 MK II NJ
I think he has a leak
I think it is in the trans. Is it a fine thin redess oil?
higgs
Aug 24, 2005
3,738
Once on the water it is pretty tough to tell what type of oil it is. His trans sump is full to the mark as is his engine sump. Ross may be right here. It does not take much to put out a big pool. I have heard onec cup of gasoline will make a slick the size of a football field.
L
L Callahan
I found the same thing in the sump area under the
engine where there was a mixture of diesel fuel and water The water was from the exchanger cooling line. With help from a buddy we found that my diesel line clamp to the engine justed needed tighten but I needed to replace the water hose. Total repiar cost $250.00. I was lucky it did not get into the bilge area on my H31, that would have been a real mess.
The intake air filter
and normal aspiration of the crankcase breather hose (depending n what engine he has) may be all that was required. Not necessary to jump to a conclusion that it's a leak.
Timo42
Mar 26, 2007
1,042
Venture 22 Marina del Rey
Florescent dye
one way to determine the source of a leak is to use florescent dye in either the motor or trans. A small blacklight will show even minute seepage. The dye and light aren't very expensive and could save a lot in misdiagnosis. I use this all the time at work. Tim
Robert
Consider other sources
Thinking outside the box... does the boat have A/C with an oil filled water pump like the CalPump? These make a mess when they come apart. I have never had one last for the full two year warranty.
Mike B
Apr 15, 2007
1,013
Beneteau 43 Baltimore, MD
Oil fill cap
The oil fill cap on my Westerbeke is a push in type, no threads. It leaks just enough to allow a very small drip into the bilge under the engine. You can barely see the oil trail on the engine but it sure is visible once it hits the bilge. Time for a new cap yes, but also another example of how it could happen.
Tim
Diesel Fuel Line
I had this problem and finally tracked it to a loose pipe clamp at the filter inlet. A very small amount of diesel would come out, migrate down the hose to a low point and drip off behind the engine bulkhead. From there it would make its way to the bilge. Tightened up and now clear.
