Oil in my Bilge
sd1953
Nov 8, 2012
30
Endeavour 38 Center Cockpit Ft. Pierce
I bought a 27 year old boat (an Endeavour 38 center cockpit) and I have been resurrecting it over the last year. This is not my first boat, but is my first sailboat. Previously I sailed other people's boats and charter boats.
When I bought the boat there was oil in the bilge (a lot of oil). I got it cleaned up and got on with my work. Last week I discovered the bilge with a layer of oil again.
I thought to check the sources of oil, the engine crankcase and the fuel.
I checked the diesel (Yanmar 4JH3E) dipstick, crankcase is full. I checked the fuel tank, no evidence of leakage there either. I followed the fuel lines, no evidence of leakage there.
So there was a layer of oil on the little bit of water in my bilge, but I cannot find the source. If I cannot find the leak, I can't fix it. I'm at a loss. What else should I be checking? Anyone else chased an oil leak around the bilge?
Jul 19, 2013
186
Hunter 33 New Orleans
Clean the engine and the bilge several times. The oil could be residual oil from a previous leak or spill. You could get Oil Trace Dye and add it to the engine, then the transmission, eliminating one or the other. If you can get the bilge dry slide paper towels under the engine and transmission and see if you get markings.
Nov 24, 2012
586
I bought a 27 year old boat (an Endeavour 38 center cockpit) and I have been resurrecting it over the last year. This is not my first boat, but is my first sailboat. Previously I sailed other people's boats and charter boats. When I bought the boat there was oil in the bilge (a lot of oil). I got it cleaned up and got on with my work. Last week I discovered the bilge with a layer of oil again. I thought to check the sources of oil, the engine crankcase and the fuel. I checked the diesel (Yanmar 4JH3E) dipstick, crankcase is full. I checked the fuel tank, no evidence of leakage there either. I followed the fuel lines, no evidence of leakage there. So there was a layer of oil on the little bit of water in my bilge, but I cannot find the source. If I cannot find the leak, I can't fix it. I'm at a loss. What else should I be checking? Anyone else chased an oil leak around the bilge?
Pretty big difference between oil and diesel in color, odor and viscosity. Not sure why you're tracking the fuel lines if you think it's oil.
Step one clean up the engine completely with no evidence of oil. Clean up the engine pan and place a oil absorbent pad.
Step two: Run the engine and and run to heat up and build pressure. Check the engine completely - up down and around. a leak should be self evident.
capta
Jun 4, 2009
5,123
There is sort of microbe that inhabits boat bilges that smells and feels like old oil. After cleaning the bilge, try putting some bleach in there and see what happens. Not to be an alarmist, but rear main seal leaks generally leak into the bell housing and drip from a weep hole under it. Very hard to see as it's generally very close to the hull, or at least the lowest point on most installations.
As above, I always line under the engine and trany with oil absorb pads to see any developing leaks. They get dirty in time so change them to keep a good visual indication of what's happening under the trany and engine.
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
It only takes a few drops to put a sheen on your bilge water. Could it be from your dipstick when you check your oil. I have a similar problem, but have not been able to locate any leak either.
Jun 30, 2010
26
C&C Corvette Navarre Beach, Florida
The same thing happened to me right after I brought home my C&C 31. It really alarmed me until I discovered the oil warning sending unit with oil around it. I went to the auto parts store with the bad one and had the guy find one that looked like it and it worked like a charm for only a few bucks. The yanmar dealer would not have let me off so easy. That was a few years ago and I haven't seen a drop of oil in the bilge since. And the oil beeper announces low oil pressure as soon as I kill the engine.
Oct 3, 2008
325
Beneteau 393 Chesapeake Bay
You said the boat is 27 years old and you have a Yanmar 4JH3E. That engine is not as old as your boat, so the boat was repowered probably 10 years ago. It is usually a very solid engine. How many hours on it?
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Sometimes when adding new oil during an oil change a person with a shaky hand might spill a little. If not completely wiped up this could find its' way to the bilge. You should pull up the floorboards and try to trace the flow of the oil to its' source. Also put a few oil absorbent pads in the areas leading to the bilge, pumping contaminated bilge water overboard is a big possible fine.
Feb 20, 2013
5
Catalina 36 Oyster Bay
Oil in bilge
A very amature mistake is that the oil filter may not have been screwed in tightly. Also different brands have different amounts of gasket face, and may leak if not well hand tightened. I had a great deal of black oil in the bilge, after an oil change, so I can say even experienced weekend mechanics can make amature mistakes.
Good luck
Gary
sd1953
Nov 8, 2012
30
Thanks so much for the replies. Your thoughts have helped me to form a plan to hunt down the source of oil.
nolasafari, Capt TJ and cookwithgas - I will perform a close inspection of the engine looking for drip and leaks. There is a metal tray under the engine that I can place an oil pad on to monitor for drips/leaks.
capta - if it is a microbe, will it make an oil sheen if the bilge pumps? My insurance covers oil leak fines, but goodness I don't want to call up and say I need to use that coverage. (Mostly I don't want to put oil in the water!)
Paul - yes the boat was repowered in 2002.
jibes138 and GMatthesen - I haven't run the engine enough hours to need an oil change (fluids were new when I purchased the boat). But it is sound advise for my oil change procedures.
Thanks all for your time and experience on this.
Jan 27, 2008
3,092
I wasn't suggesting you had changed the oil. What I was suggesting was the prior owner may have spilled some while changing it in the past and it is seeping down a path to your bilge. On my engine the oil fill is near the rear of the engine and there isn't much clearance overhead for funnels and oil bottles. I have to be very careful not to spill some. I usually use a plastic cup and fill it repeatedly to get 4 quarts in there. Even if you find a leak and stop it you will still have oil from the leak all the way to the bilge, you need to clean that whole path to make sure you don't contaminate the bilge any further. Usually this means pulling up the floor boards and using rags and absorbant mats to mop up any oil and oily water you find. Also put a few oil absorbant pigs in your bilge to absorb any oil that gets in there.
Oct 17, 2011
2,809
Ericson 29 Southport..
Bear in mind a teaspoon of oil/fuel in the water looks like a five gallon spill from above.
(That was also what I used to tell bikers that fell in the road. A teaspoon of blood looks like a quart on the pavement).
It does..
sd1953
Nov 8, 2012
30
jibes138 - I see your point. I will need to inspect the engine to see if there is an old spill or leak that is dripping slowly into the bilge. I am a bit fortunate in that the engine compartment in a center cockpit layout is fairly roomy compared to aft cockpit boats I looked at before buying this one.
Chris - after I used the wet vac to remove everything from the bilge, I was kind of amazed at how little appeared to be oil and how much was dirty water. But I still can't allow any to go over the side...
Jul 28, 2012
35
Catalina 27 Annapolis
If you've bee out sailing its possible that the oil came out of the dipstick tube while heeled, especially if the dipstick doesn't seal well.
Also, if you've motorsailed the heeling (esp. If excessive) and running engine may have forced oil out of the dipstick tube
Josh
Dec 30, 2009
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
Before my repower my renault ws blowing oil all over, final killer was head gasket. I would have clean water in the blige, alittle dirty oil, and diesel it looked like the Valdez when I was running it. It was a dirty black pool....but if you used a hand pump and placed carefully at the deepest point the water is heavier and would come out just a little colored, the very top was oil and diesel....yick.. Red
