Here is another article on oil in a marine engine.
It takes a slightly differnt point of view on why you need to run some of these small diesel engines at higher RPM's. While many would like you to believe that you are saving your engine at lower RPM's this article reinforces Yanmars position on running your engine on traditional oils and higher RPM's.
http://coxengineering.web.officelive.com/oil.aspx
