Oil in bilge/Tractor parts
David
I've discovered 2 problems with my M3-20 diesel. I recently noticed oil in the bilge. The yard checked it out and said the main bearing seal is gone. Estimate is about $2K. How big of a job is this, has anyone gone thru this recently. Secondly the water pump is also on the way out and needs to be replaced. Is this something that can be obtained through Kubota or is it strictly a marine product and only obtained through Universal?? Thanks
John Visser
Parts
Don't know about hte seal. I assume the quote is to pull the motor, do the seal, reinstall the motor? Pump - fresh or seawater? Sea water is available from Depco Pump and others; fresh is a Kubota item. jv
