oil for yanmar 4jh5e
gorkem
Jan 29, 2015
8
Custom Fisher Turkey
Hello All, I am planing to change oil of my Yanmar 4JH5E myself. Last year the Yanmar service put ELF 15/40 API CH-4/SJ oil in it. Does it matter if I use another 15/40 oil with different API class oil this year ? Such as CF, CF-4 or CI-4 which are still recommended by Yanmar... Considering the residual oil left in the engine, would it be a problem mixing different API class oils?
Thanks for your help.
Nov 6, 2006
10,151
Best to not mix full synthetic and conventional oils.. I am not familiar with ELF oils, but any good conventional multi-grade 15/40, diesel oil (ELF also) like Shell Rotella T or the Esso or Chevron equivalents are fine.
Dec 25, 2000
5,950
Engine Oil
I've been using Delo 400 oil in our 4JH2-TE for years.
Beneteau 323 Annapolis MD
Your service manual should specify the minimum API. Anything farther down the alphabet is newer, and of better formulations. So, don't use any oil with a letter closer to the front of the alphabet.
