Oil filter Yanmar 18 hp
Joan
Does anyone have their engine book handy? What size oil filter for Yanmar 18 HP on the 29.5 Hopefully someone can save me a trip to the boat. Thanks
Dec 2, 1999
15,184
Oh Joan, oh, oh, oh!
Joan: Obviously you do not know about the Yanmar parts list on the site. Reference Library Hunter Q&A '99 boat shows -----> Yanmar parts Yanmar tips Prop/Shaft Sizes Check it out, everything you wanted to know a somethings that you do not care about!
Stephen Ostrander
filter #
Yanmar #124450-35100 Fram #PH3593A Purolator #L14459 Bookmark this site: www.torresen.com they have all Yanmar info on line and you can also order online.
P
Paul Akers
Non-Yanmar Filter - use caution
As posted here in the past, non-Yanmar filters may lead to futere problems. I inquired with Yanmar and they said this...Aftermarket (non-Yanmar) filters fit, but they lack a check valve within the filter that allows oil to drain back out of the filter and/or the engine. After repeated start-ups, oil must be recirculated thru the engine instead of just resting up there inside. Eventually, this leads to unnecessay wear on the engine. It may just be worth spending $4.00 more for that Yanmar filter in the long run.
Joan
Thanks Steve, Stephen and Paul
Thanks for the sites and other info. Joan
Sam Lust
Oh Boy, another Controversy!
Yanmar is VERY sensitive about after market parts. They appear very jealous of their profits. A friend of mine hacksawed apart a NAPA filter next to a Yanmar filter. He found them both to have the same check valve inside. I just can't see a major maker skimping on a specification like that.
