engine is a yanmar 3Jh4e, with an oil cooler problem. Yan service manual para 8.3 ´lube oil filter´ diagram shows the oil filter threading onto a stud. There is a large nut holding the cylindrical oil cooler body onto the stud. 2 pipe nipples for hoses carrying antifreeze come out of the oil cooler at 9 o´clock - inlet -- and 3 o clock -- outlet . Looks to me like after the oil filter is removed, the "lube oil cooler retaining nut " just threads left counterclockwise off the stud , then the whole oil cooler assembly can pull off .
1) is that correct ? Or is there more disassembly??
2) what is the nut p/n 129417-33110 diameter- the biggest 30 mm socket i have--(which yanmar recommends in its ´tools list´ )does not fit onto this nut ....
3) is there any truth to the internet ´advice´ that you can just bypass this cooler on these yanmar engines -- by bypassing the cooler , joining the inlet antifreeze hose p/n 129508-49030 with a connector piece of same diameter to the outlet hose, p/n 129508-49040. And that this bypass of the cooler does not adversely affect engine oil temperatures?
note that the piping diagram for the oil cooler shows 2 rubber hoses both ´9xt3.5 ´ but it sure looks to me like the oil cooler outlet hose is a substantial few mm s larger at the coolant - pump end than the inlet hose...
the oil cooler /hoses are special order that will probably not come til halloween,, in the meantime the engine is down til i get this fixed......
