This is my point! And in addition, listen to this
I hear ya Fred! I have a cat that weighs around 30 lbs and constantly needs attention.Concerning the manual not saying anything......This is exactly my point! Yes, manuals are wonderful for the basics. But the details are missing! And the best place to get these details are from a mechanic that works on these engines and has been around the block a few times (like my grandpa....Of course he has been dead for about 10 years. But just before he died, it was his goal to go around the block one last time. In his younger year, he went around the block so many times, they used to call him Block Head.Well, Yes, with a car you need to run it for about 10 minutes or so before you test the transmission fluid. And to boot, it is best to test it while the car is actually running. (for those of you who have never checked the transmission fluid in your car, "running" does not mean in motion! It is o.k. to check it while the car is parked. Before I learned this myself, many used to wonder why I would climb out on the hood of my car on rt. 33). Any way, checking transmission fluid in a car at idle temperatures is true with just about any vehicle if not all of them. But listen to this one: When I called Torresen, the mechanic said to test it cold. And he went on to tell me that the manuals will not tell you things like this. My assumption is that they do not really want you to fix your own motor. Most companies that produces products such as engines try to make it so that you will have to go to a authorized mechanic. And if you do maintain or repair your own engine, sooner or later, the things not mentioned in the manual leed our repairs and maintainance practices to cause our engines to eventually fail. It is a good thing that the mechanic at Torresen in Michigan is so nice!Any way, he said make certain that when you check the level of the transmission fluid or oil (depending on your motor), to simply lay the dip stick in but do not screw it in.If anyone would like to double check this by getting a second opinion, it would be most important. The reason I say this is for this reason. The difference in fluid level between full checking with a dip stick screwed in as apposed to simply laid on the threads, is about 1/3 of an inch. This will probably not hurt anything. But still, it would be nice to know. And the difference between checking it cold as apposed to hot, can mean the difference of about 1 inch of fluid...not to mention laying the dip stick in or screwing it in as well. :-(In addition, I asked the mechanic where the fluid/oil should come to. On each dip stick, there are a series of X's. If the fluid lies near or on the lowest x, you need to add transmission oil or fluid. If the fluid lies on the upper most x, this means your transmission is properly full. He said this...... You may fill your transmission to the upper most x. And if you go over a bit, this will not harm your transmission. But do not go too far over. If you go too far over, you will ruin gaskets, seals and eventually bearings. I asked him how far was too far. And he said to me that you can go over about 1/8 or so of an inch above the upper most x.Now, if I can only find a way to keep my kitty from eating all day and night long. Shoot, I will be laying there in bed. And this cat will insist on going to the other room 3 or 4 times a night to chow down on kitty food. She is getting so big, her behind is bigger than my 5 year old daughter's bottom! And she, the cat, goes through about 25 lbs of food in 2 or 3 weeks!Marina
